Brief Description: Cutting, fitting, priming, and repeat
I cut the finishing lines on the empenage fairing and drilled the tinnerman connection points. (on 4 points on each side I drilled out the existing rivets to add nut plates to the connection point). I ordered Click Bond nutplates for the points on the horizontal sabilizer where the fairing will connect.
I also drilled and bolted the canopy stops to allow the canopy as much rear movement before intersecting the empenage fairing.
