Brief Description: Vinyl wrapped the front seat assembly
I applied the 3m 1080 carbon fiber textured vinyl wrap to the seat assembly. Using the same 3 color process as the rest of the interior finish. White vinyl with black underscore below the wihite stripping. Then I applied the Graphite color top and bottom.
Applied black carbon to the upper and lower angle. Overall excellent finish and I wish I had applied the vinyl to the rest of the pieces prior to riveting, but I am where I am and I'll have to live with the vinyl over the rivets on the side walls. (Probably better anyway, if I decided to change color or paint the surfaces, instead of wrapping.)
I only brought foreward the wrapping vinyl a couple inches of the top and bottom since it will be covered with the cushion/upholstery.
I do like the what the seat back finished up after riveting. (Riveting is recored on separate entry to keep my time correct on the interior finish vs building)
Forward side of the front seat, which will be covered with upholstry
