Brief Description: Electrical wiring, mount VPX-Pro and rear ski rack
Mount the rear builkhead ski rack.
Mounted vertical power VPX-Pro to theforward avionics planel. I was really happy that I could keep the VPX inside the avionics compartment. Originally we planned to mount it in the baggage compartment due to space, but found vertically mounting it to the access panel/door assembly between the baggage and avionics compartment would work. Mount the ground bus to the rear avionics panel.
Clean up the wiring and coax cable attachments zip ties and adel clips. Add rash protection.
