Brief Description: Assembly of right wing leading edge
Removed protective coat on skin of leading edge (Right wing) clecoed into place the ribs for the leading edge. Match drilled holes to full size. Attached the leading edge to the main wing spar and match drilled main spar holes to leading edge skin.
