Brief Description: Leading edge assembly for left wing
I finished the match drilling on the bottom of the right wing skin. Removed excess clecos and began the assembly of the leading edge ribs with the skin in the cradle it was fairly simple. I made final adjustments to the stall warning system and clecoed it into place. Fitted the leading edge on the left wing for storage while I work on the right wing leading edge.
I had to make modifications to the wing stand attachement point on aft edge. Wing skin was obstructed due to how close the resting angle iron support was mounted. I mounted a piece of 2x2 angle to the back of the existing system and it provided enough room to fit the leading edge assembly to the main spar assembly.
