Greg's RV-12 Classic N719VA
Date:  5-27-2021
Number of Hours:  2.50
Manual Reference:  SB00023, 46
Brief Description:  torqued engine bracket bolts,
Finished the SB00023. Torqued the engine bracket bolts that hold the bracket to the firewall. Had to use a new swivel socket knuckle to reach it okay. Installed all four cotter pins on the castle nuts.
Manual 46-11 steps 1 & 2, attach the soft start (Easy Start per Rotax) wire attached to the engine to the starter relay. Wire tied to the orange wire and jumper on the starter relay. Re-attached one bolt and one nut on the ignition system that were removed early one in the engione installation (see 46-03 step 5 a & b see three arrows in figure 4 pointing to what was tightened). Used Loctite 222 on the nut. The bolt has a lock washer. Also tightened another bolt/nut combo with lock washer.
Manual 46-12 step 1, partial 2, 3 & 4, Connect the oil pressure connectyor to the engine and wires from the firewall.
