Greg's RV-12 Classic N719VA
Date:  5-25-2021
Number of Hours:  2.50
Manual Reference:  SB00023
Brief Description:  replace engine mount bracket per SB00023
Per SB00023 replace the engine mount bracket WD-1221 with redesigned one WD-01221-1. Partially completed. Mounted and torqued to approx. 170 in-lbs the bolts holding the bracket to the engine.
Wa not too difficult to replace this since there is still more wiring to do and not much in the way.
