Today I did a few of the odd jobs that where still outstanding while I wait for the paint on the wing to dry. Replaced the bolts in the rudder with ones of the correct length, tie wired the elevator cables where they connect to the elevator horns, installed the fuel line grommets in the centre console and then installed the fuel line itself. Lots of little fiddly bits and still more to do, the centre console elevator hore bolts are going to be a pain in the rear to either fit split pins or tie wire to, as there is not much room to get your hands into that space, also not being able to see the bolts properly does not help.
