Brief Description: Second coat of primer on fuselage
After letting the first application of undercoat dry for 1 hour, I went over the whole fuselage again and gave it a second coat. Believe it or not, the entire job (two applications of undercoat) required less than 1 litre of paint...and that was after I thinned it down 30% so it would spray properly, go figure.
The second coat has much better coverage, but you can still see through it
Another view, I hope the paint goes on like the primer did
