Its raining this afternoon and I was not really feeling in the mood, but thought yet again some progress is better then none, so did some more odd jobs, tightened the bots for rudder pedels, added fuel overflow line to the fuel pump, cut the rear sections out of the bottom rear of each wing to allow finger access to install the rear spar bolts and adjusted the angle of the brake pedels to what I am guessing will be comfortable. I'm off to Malaysia next week for 5 days so this is probably the last progress for a little while other than adding fluid to the brakes tomorrow, hope that does not get to messy.
