Brief Description: Bottom cowl to fuselage attachment
The whole process of installing the cowl onto the fuselage sides took lots longer than I had anticipated, but like everything else that comes with few instructions, its a learning experience. I have decided to install 4 camlocks on each vertical side of the fuselage, and I am still debating if I should install 3 or 4 camlocks across the top or horizontal section of the fuselage. tomorrow night I will finish installing the camlocks on the right side of the fuse and then onto the top.
Right edge of fuse marked on cowl, back drilled and clecoed in place
Left side after marking edge of fuse on cowl etc. with camlocks installed
