The right side of the fuse is now complete with its camlocks installed, I have to admit this side was much easier to install after yesterdays efforts / learning curve. I then proceeded to measure the top edge of the forward turtle deck and transferred these measurements to the top of the cowl. I have decided to only install three camlocks across the top as its all held so securely in place that I can't see the need for any more fasteners. Plus the front of the cowl around the prop flange is also secured by camlocks, I am pretty sure its not going anywhere...besides my Bi-plane only uses three fasteners on each surface and its cowl weight is much higher, nothing like justifying something is there.
Camlocks installed on the right side of the fuse
Marking the distance to the edge of the top forward turtle deck
