Tonight I fitted the EGT probes to the two rear exhaust stubs, I am not sure how much use they are going to be, given that the carbie is self regulating, guess I should at least see if I am running lean or rich. I installed both probes about 52mm from the face of each exhaust stub, the recommended location is between 50mm to 100mm as long as both are in the same place.
