I have basically completed the engine side of the firewall wiring, I just need to install the two exhaust gas temperature probes and run these back to the instrument panel. I have also run out of spade connectors so will need to buy some more so that I can complete the wiring for the tacho and other gauges.
Battery and started solinoid wiring completed
Mag switches, tacho pickup and rectifier wiring completed
Oil temperature and oil pressure (just out of frame) wiring completed
