I am back again after a trip to the Philippines for work, sigh, this really puts holes in the build effort but you gotta earn a living. Today I installed the Strobe driver unit and wired the power and the cables and connectors into the fuse so that its all easily disconnected should a wing have to be removed or in this case installed. I also installed the female version of the same type of plug onto each of the cables in teh wing.
Strobe driver unit installed in the center of the fuse floor
Male connector installed into the fuselage side to allow easy connect / disconnect
Female plug installed onto the cable for each Head unit in the wings
