Eddie's Zodiac XL Project
Zodiac 601 XL
Drill all holes to #30 and #20 as per plans
Drilled all the left rear fuse holes out to #30 and the H/T brackets to #20
Same for the right side
Top rudder bracket drilled and bolts installed
RV-7 Home
Zodiac 601 XL Home
2696
Ailerons
Baggage Tray
Brakes
Center Fuselage
Centre spar
Cowling
Fairing
Firewall
Flap assembly
Flight testing
Front Fuselage
FWF
Instrument panel
Left Wing
142
Mounting Horizontal
Rear turtle deck
Test flying
Undercarriage
Undercarridge
Upgrade
Upholstery
Weight and Balance
Wheels and brakes
554
