Eddie's Zodiac XL Project
Zodiac 601 XL
Rivet Right side of fuse
I disassembled the right sdie of the fuse, deburred, dimpled and applied cortec before riveting it in place. only the top longeron has not been riveted because I will need to remove this later once the rear turtle deck is installed.
Right side of fuse
RV-7 Home
Zodiac 601 XL Home
2696
Ailerons
Baggage Tray
Brakes
Center Fuselage
Centre spar
Cowling
Fairing
Firewall
Flap assembly
Flight testing
Front Fuselage
FWF
Instrument panel
Left Wing
142
Mounting Horizontal
Rear turtle deck
Test flying
Undercarriage
Undercarridge
Upgrade
Upholstery
Weight and Balance
Wheels and brakes
554
