Eddie's Zodiac XL Project
Zodiac 601 XL
Cable fairing exits
Cleaned up the Nylon 66, the gap is slightly larger then the required 1/8 inch
The second one turned out better, practise makes things better
Slot in the left side fuse for rudder cable
RV-7 Home
Zodiac 601 XL Home
2696
Ailerons
Baggage Tray
Brakes
Center Fuselage
Centre spar
Cowling
Fairing
Firewall
Flap assembly
Flight testing
Front Fuselage
FWF
Instrument panel
Left Wing
142
Mounting Horizontal
Rear turtle deck
Test flying
Undercarriage
Undercarridge
Upgrade
Upholstery
Weight and Balance
Wheels and brakes
554
