Removed the nose skin so that I could dimple the top section, while it was off, I dimpled the top of the main spar and the tops of all the nose ribs using the hand dimpler. I then coated the nose ribs and the top of the main spar with Cortec and then with Anne-Marie's help dimpled the nose skin. Once this was done I ran the pitot and static lines into the wing and held them in place with cable ties. One cable tie was passed through a hole I drilled in each of the ribs the lines passed through, and the second cable tie was then looped through this first cable tie so that it supports the line without actually clamping it to the rib.
Pitot and static lines entering the wing through lightening holes
Cable tied through RR#1-4
With string attached so that the lines can be pulled through
