Brief Description: Rivet bottom skin of left wing and install access
I had a very slow afternoon, was feeling dead tired after the work week and flying this morning. I installed the aileron bellcrank access plate and cover. I am not overly pleased with the job I did cutting the cover out, I managed to leave a few to many wavey edges because I didn't do a initial cut about 10mm from the cut off area and then finish with a final cut, its amazing the difference this makes to the quality of the finish. Anyway I'll see if this grows on me, if not I'll cut another out of some spare aluminium. I also pop riveted the rear half of the bottom skin, I can't finish this until I have mounted the nose skin and back drilled with the #20 drill and then deburred and dmipled. The front of all the rear ribs have been riveted to the main spar, I just need to do the rear spar now and then its on to the nose skin.
Riveted the rear half of the bottom wing skin
Riveted the front of all the rear ribs to the main spar
