Brief Description: Drilled hole for the pitot and static, mounted to
Just before my energy ran out, I drilled the hole for the pitot and static port O/B of RR#5, 150mm back from the centre of the spar as per the drawings, I then marked and drilled the base of the pitot and fitted to the wing. This will of course be removed after I add the air line tubing and fix this in place. I am going to leave a length of tubing protruding from the bottom of the wing so that I can attach the pitot after the wing is finished.
