Brief Description: Attach nose ribs and hang nose skin
This morning I started the day by attaching the nose ribs after tehy where deburred, dimpled and coated with Cortec. Once they where pop riveted in place Anne-Marie gave me a hand to lift the nose skin into place under the rear skin, I had previously drilled the front of the rear skin to the main spar and was going to use this as a locating template to back drill the nose skin as can eb seen in image 1. I then extend the rear rib rivet lines onto the nose skin in preparation for drilling the #40 pilot holes
