Brief Description: Back drilled bottom skin and nose ribs
No pictures today, I back drilled all the holes in the bottom skin out to #20, their finial size, deburred all the nose ribs and marked the nose rib centre lines in preparation for lifting the nose skin into place. Not sure if I will do the nose skin first or debur and dimple the bottom skin. Either way, I should finish off all the wing internals which include drilling all the rear ribs to fit gromets for the wing tip strobe and also run the tubes for the pitot and static lines.o
