Brief Description: Aileron access cover and tie down ring
Managed to get a bit of work done after flying, I was aiming to drill the holes in the bottom skin out to #20, but ran out of energy, it can wait for another day. The wing is almost ready to slide the nose skin into place. I still need to enlarge the holes in the spar to #30 and draw the centre lines on the nose ribs, perhaps I'll manage to get this done tomorrow.
Cut out out the aileron access cover, now I just need to attach the support plate under the skin
Cut the hole in the bottom skin, drilled and clecoed the tie down ring in place
Drilled the #40 holes in the front spar and rear skin, need to enlarge this one size for nose skin
