Dave's RV-10 Build Log
Date:  1-10-2020
Number of Hours:  4.00
Brief Description:  Cleaned oil screen, lower plugs, refilled engine o
Cleaned the lower spark plugs with alcohol to remove the preservative oil. Re-installed the plugs and torqued to 35 ft-lbs.
Re-installed the oil drain plug and safety wired it. Removed the oil suction screen from rear of engine and cleaned it. Replace the screen and safety wired the screen plug.
Added 8 qts of AeroShell 100 mineral oil per the Lycoming instructions.
