Dave's RV-10 Build Log
Date:  6-12-2019
Number of Hours:  7.25
Brief Description:  GMA 245 Wiring Completed, Alternator and Battery C
Completed the wiring in the GMA 245 Audio Panel connectors by adding wires for the rear seat headsets and microphones. Attached the connectors to the rear connector panel, and then installed the rear connector panel to the GAM 245 mounting frame.
Measured and installed the #6 AWG cables from the Primary Alternator and Battery shunts to the center breaker panel location.
Cleaned up some of the wires on the left side of the panel and routed some to the right side. Installed a few large tie-wraps to help organize wiring/routing. Tied many of the cable bundles with waxed cable lacing to replace temporary tie-wraps.
