Dave's RV-10 Build Log
Date:  3-5-2018
Number of Hours:  3.00
Brief Description:  Cowl To Filtered Air Box
Removed the balloon from the air inlet and sanded down the fiber glass cast on Friday. Trimmed the excess fiberglass from the back side of the inlet.
Mixed up an epoxy and Micro mix that was a bit thick (but not to peanut butter consistency) and applied to the fiber glass layed on Friday.
Installed the standard Van's NACA vents on both sides of the forward fuselage using Pro-Seal. Held the vents in place with duct tape to allow the pro-seal to cure.
Installed a screw and washers to plug the hole in the Cyl. #6 baffle, similar to the one called for and previously installed in Cyl. #5 baffle.
