Dave's RV-10 Build Log
Date:  9-15-2017
Number of Hours:  5.00
Brief Description:  Fiberglass Layers on Windscreen & Touch up Paintin
Added 3 more layers of fiberglass to the windscreen fairing. I continued to use black dye in the Epoxy, but didn't use any micro this time. As with previous layers, sanded the prior cured epoxy to smooth out the rough/high spots before starting the additional layers.
With the additional fiberglass layers in place, I masked the doors in place as well as the interior of the plane, and then did touch up paint spraying on the interior door surfaces. This took more time to mask everything that I expected, but it was still a bit faster than it would have taken to remove the doors before spraying.
