Complete trailing edges of Elevators after epoxy had fully cured: - Remove clecos and aluminum angle from trailing edge - Clean up trailing edges from glue and form release material, and file edges - Back rivet trailing edges with countersink shop heads on bottom of elevators - Rivet edges of elevator to close up - Match drill trim tab hinges, debur, dimple and rivet
