Dave's RV-10 Build Log
Date:  2-29-2016
Number of Hours:  8.00
Brief Description:  Rudder Construction
Cut stiffeners, debur, dimple
Dimple rudder skins (2)
Back-rivet stiffeners to skins
Rivet ribs to skins
Rivet shear clips to stiffeners
Join stiffeners and shear clips using blind rivets
Crease the skins over the counter balance weight, drill, debur, dimple and secure with flat head bolts and nuts.
Skins "pillowed" over center of weight, so drill additional hole in center between the weight bolts, debur, dimple, and secure with blind rivet (CS4-4)
Glued trailing edge with structural adhesive and cleco to aluminum angle to hold straight while curing.
