Wesleys Web Site
Date:  6-29-2021
Number of Hours:  1.50
Manual Reference:  Canopy pin plate
Brief Description:  drilled and mounted the soft plastic canopy rail p
Drilled the rear mounting pin plate to the bulkhead. Dimpled the bulkhead and countersunk the soft plastic pin plate. Drilled the rear of the pin plate and pressed in the nut for mounting the pin plate to the rear bulkhead.
I'm still struggling with the finish on the interior of the canopy skirt. While the Sikaflex adhesive indicates it's paintable. The black paint is not curing to the Sikaflex. I use MEK to remove the paint from the adhesive, which leaves a different finish than the paint; which is what I guess I will have to live with. The Sikaflex has a very dull mate finish and the paint is more of a satin/semi gloss finish and the Sika primer is a high gloss finish.
