Brief Description: Route Coaxial cable run for rear WAAS antenna
Route RG400 coaxial cabling from rear WAAS anntenna location to the Garmin GPS unit. Drill through holes in bulkheads and set zip tie pads, epoxy to fuselage.
Paint out the connection point for the wing spar connection. Apply Graphite wrap to both cover pates and to the rear facing side of the wing spar bulkhead. Wrap the flap motor arm.
