Brief Description: Wiring for various components as well as air lines
Ran the air lines for the Angle of Attack and Pitot line.to wing root.from ADAHARS. Secured lines at various connection points.
Drilled mounting locations for the communications antenna and the Transponder antenna. Fabricated back plate for the Transponder antenna.
Pulled the cabin light wires up through fuselage for LED strip lighting under the canopy rail.
Wraped the rear bulkhead with graphite vinyl as wellas the two side plates for the rear fuselage arm rest/flap cover plates. Mounted the rear seat heat switch.
Secured more of the wiring runs to clean up wiring. Connected the USB power and ground lines.
Air lines for AOA and Pitot to ADAHARS
Rear seat heat switch on wrapped side plate for arm rest
