Brief Description: Wiring for rear of fuselage and left side
Finished up the rear fuselage wiring runs which included the elevator trim motor, final connection for the ELT including the buzzer and grounding point. Cleaned up the wiring. Started on the left wiring run which includes the headphone jacks for pilot and copilot. Completed the wiring run for the high preasure fuel pump and the main left side run down the gear leg and through the wing bulkhead. Cleaned up some of the previous wiring runs includeing friction guard and wiring zip tie points. I also put a dab of silicone on the zip tie points to secure them as they get older.
