De-pinned the various Garmin components pulled the main right side bundle of wire.
Mounted the GMU 11 and the ADAHARS to the bulkheads and plumbed the Static lines for both left and right static lines and then back to the ADAHARS. Secured the flex tubing with Adel clips. Pulled the right main wire run and re-pinned the various lines and mounted the friction guards. Secured the two lines for the wings to the outer fuselage.
