Wesleys Web Site
Date:  5-29-2021
Number of Hours:  7.00
Manual Reference:  Wing tip mod
Brief Description:  work on wing tip modification to mount with hinges
final deburing, dimpling, and countersinking for final riveting of hing to the fiberglass wing tip as well as the riveting the hing to the wing end.
I used soft rivets, made from aluminum, to rivet the hinges, with the fiberglass spacers t o the final assembly (as suggested I drilled in additional holes and added the larger holes for fiberglass rivets attachement.
I cut away the two pieces of the Wing tips to provided better georraphy .I also riveted the hing assebmly to the end point;
Finished hing riveted to wing end
