Bloted on the locking mechinisim stop block and verified everything would work.
Drilled the through bolt on the canopy roller to the canopy frame. I set the Flyboy canopy stop in place and drilled the connection bolt the same on both left and right side; in the strange event that I move or added the lever arm to the right side. Set the bolt on the left side and screw on teh right side. I clapped into place the Flyboy stops for both the mid stop as well as an additional stop about 8" back from the forward frame. tested and drilled the stops. D/A the top aluminum cover and prime/paint cover plates. (I opted to fabricate new spacer blocks that were only 3/16")
Canopy roller connection to canopy frame with the Flyboy slide arm
