Brief Description: Sand and fitting of the canopy skirt
Sanded down the previously applied fiberglass around the rear section of the canopy skirt. Laid in more fiberglass on the rear notch about one inch section to the right of the notch. Hoping this will be my last under lay of fiberglass to improve the fit.
I also applied a skim coat over the right rivet sections and to the rear of the canopy skirt were I had sanded down past the original skirt notched sections.
