Brief Description: More work on the canopy skirt fit to the fuselage
In preparation for the Sky Design landing gear and 6x6 tires/fairings I pull the landing gear off the plane and set it lower for better access, since the panel is getting closer to completion.
I cut out the notch, again...Then went at the rear section of the skirt with the sander.Tore the top coat down to the fiberglassing I had previously laid in. Laid another section of fiberglass on the inside and using some fillerMicro smoothed outthe top coat of the rear canopy.
