Brief Description: Sanding, filling, and fitting on canopy skirt
After allowing the filler/fiberglass to cure on the rear connection between the two halfs of the canopy skirt I aggressivly sanded down the topy layor to provide closer connection to the fuselage. While it is much better, I'm still quite a long way from a tight fit. I cut back in the rear notch for the canopy rail.
