I started out with the idea that I would wet out some fabric for the foam pieces that I had previously cut for the left elevator. After a couple attempts to get the fabric in the edges I went back to resign with Micro filler. Packed the edges with resin filler and then filled the two pieces on the left elevator. I tried feather in the forward seam to see how it will turn out.
