A bit of frustration as the canopy is turning a bit as a re-fit it back on the welded frame. Front windshield is coming along but I don't see how the back is going to touch the welded frame. I'm still unable to get the plastic to even clamp to the rear frame.
I'm concerned about the idea of riveting the plastic canopy to the metal frame. I continue to research adhesives and builders past experience. Many of them have glued the plastic, but mostly for the other models that appear to be better fitted to the frame and don't require as much preassure to pull in the sides.
