Brief Description: completed the wing connection tabs for left and ri
Cut the two 1/4" slots into the forward tank tabs. Used a drummel for the initial gut and a 1/4" grinding wheel to add width and a file for the final deburing. ( The left tabe was a new tab since during the wing attachement phase I found the connection bolt too close to the edge. So I needed to prep and paint the the tab, then torque the bolts back onto the fuselage)
Set, drilled the two nutplates for the fursealge tabs debur and rivet the nutplates into place, for the breakaway connection on the forward tabs.
