Wesleys Web Site
Date:  3-9-2019
Number of Hours:  9.00
Manual Reference:  Left Elevator
Brief Description:  Rebuilding of left elevator Rivet and final assem
Finished riveting the skin to the sub structure. Rivet the trim tab spar including the blind rivets along the skin.
Form the radius for the leading edge of the elevator. Rivet the leading edge using blind rivets.
Attach the trim tab to the elevator. Wire tie the hinge pin to the tab.
Mount electrical trim and adjust linkage to align the trailing edge of the trim tab to the trailing edge of the elevator.
Mount elevator to the horizontal stabilizer. Removed elevator and adjust rod-end bearings and jam nuts to align elevator horn aligns with bearing and right elevator.
Finally back to zero.
Left elevator mounted to stabilizer
Left and right elevators mounted
