Brief Description: Debur match dril cover plates for lower midcross m
Deburred the edges of the two (Left and Right) cover plates on the mid cross member structure. Left cover plate has the fuel selector valve on it.
Bolted into place the mounting bracket for the fuel valve. Match drill the interior hole on bracket attaching to the mid cross memeber. Counter sink the screw hole. Deburr holes.
Bolt cover plate to both left and right sides. Match drill the outer nutplate holes into the mid longerons for attachement. Remove cover plates and debur holes.
