Brief Description: install the screws/bolts on the left side
While access is difficult, but much better with the larger access panels on the gear boxes. I rolled the plan back to the upright position and inserted the screws for the left side skin. Torqued the bolts to 30 inch pounds (25 plus the 5 inch pounds for the lock nut friction for 30 inch pounds) applied Torque seal to the bolts
