Brief Description: Drill main 7/16" holes in bracket and friction pla
It takes a little clamping and blocking to secure the heavy gear legs to the drill press plate. Once secure the drill press makes quick work of the large hole. Then clean and resecure with friction plate bolted in place and clamp and block the gear leg again for drilling the back half of the hole through gear leg and friction plate. Completed both lefts left and right
