Wesleys Web Site
RV-8
Assembly
Side Skin riveting and assembly
Back riveted the middle Longerons to the left and right rear side skins
Cleco the rear skins to the fuselage/mid skins and upper longerons
Rivet the Stabs on the 811 rear bulkhead. Match drill the lower holes to the 409 WD tailwheel assembly.
Match drill the 1/4" holes in the tail wheel assembly to match up to the Slab assembly and tailwheel weldment''
Trim the tabs on the very far end of the Longerons
Main 809 bulkhead
Stabs in the 811 bulkhead
RV-8 Home
2038
106
146
106
134
Fiberglass
Finishing Kit
766
Mistake/error
426
