Brief Description: Finishing up the gear box assemblies
Match drilled the large bolt holes on the 813 weldment and drilled the mounting angles to the 813 weldment. Disassembled the entire assembly and debured the assembly. Rriveted the 822 weldments to each of the box assemblies..
Torqued all fo the bolt attachments to specification 22 inch pounds
shop head rivets on the insdie of the box assembly. Torque seal on the bolt attachments
