I attached the jig to the tooling holes to align the aleron neutral position and set the push rod jig into place. Set the jam nuts and confirmed linkage.
I'm concerned about where it is rubbing against the rear spar of the wing assembly. I think I will need to possibly cut out some clearance. I also need to get a protractor and confirm the range of motion for the stop location.
